Philco 77 hacked?
Ccomer
Transformer being a power transfer device, the radio likely used the same power with two transformers as it would with one. Corrected for core losses. In short, it is not twice. Maybe 10% or so more.
Philco 77 hacked? - by ccomer1955 - 08-06-2014, 08:02 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 12:15 PM
RE: Philco 77 hacked? - by morzh - 08-07-2014, 01:15 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 03:29 PM
RE: Philco 77 hacked? - by morzh - 08-07-2014, 03:38 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 04:36 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-07-2014, 04:37 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 05:44 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-07-2014, 05:47 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 09:07 PM
RE: Philco 77 hacked? - by morzh - 08-07-2014, 10:54 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 11:42 PM
RE: Philco 77 hacked? - by Arran - 08-08-2014, 03:02 AM
RE: Philco 77 hacked? - by morzh - 08-08-2014, 09:30 AM
RE: Philco 77 hacked? - by ccomer1955 - 08-08-2014, 11:12 AM
RE: Philco 77 hacked? - by Paul Philco322 - 08-08-2014, 12:43 PM
RE: Philco 77 hacked? - by morzh - 08-08-2014, 12:56 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-08-2014, 09:52 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-12-2014, 03:07 PM
RE: Philco 77 hacked? - by morzh - 08-12-2014, 03:38 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-12-2014, 10:05 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-23-2014, 03:04 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-24-2014, 08:04 AM
RE: Philco 77 hacked? - by ccomer1955 - 08-24-2014, 10:35 AM
RE: Philco 77 hacked? - by ccomer1955 - 08-25-2014, 01:28 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-28-2014, 11:56 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-29-2014, 05:31 AM
RE: Philco 77 hacked? - by ccomer1955 - 08-29-2014, 12:31 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-29-2014, 05:39 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-29-2014, 06:17 PM
RE: Philco 77 hacked? - by ccomer1955 - 09-01-2014, 11:54 AM
RE: Philco 77 hacked? - by ccomer1955 - 09-15-2014, 02:08 PM
RE: Philco 77 hacked? - by OZ4 - 09-16-2014, 01:41 PM
RE: Philco 77 hacked? - by ccomer1955 - 09-16-2014, 05:34 PM
There are currently 9912 online users. [Complete List]
» 2 Member(s) | 9910 Guest(s)
