parted out 38-116
It has the grill bars too. They are off to the side. The glue dried out on them too and they just popped off nicely. It really is like a kit project.
parted out 38-116 - by SteveJB - 08-06-2014, 09:03 PM
RE: parted out 38-116 - by morzh - 08-06-2014, 09:17 PM
RE: parted out 38-116 - by Arran - 08-06-2014, 09:19 PM
RE: parted out 38-116 - by SteveJB - 08-06-2014, 09:25 PM
RE: parted out 38-116 - by Arran - 08-07-2014, 09:18 PM
RE: parted out 38-116 - by codefox1 - 08-08-2014, 05:39 PM
RE: parted out 38-116 - by PhilcoJohn - 08-09-2014, 07:31 PM
RE: parted out 38-116 - by SteveJB - 08-10-2014, 09:11 AM
RE: parted out 38-116 - by codefox1 - 08-10-2014, 07:44 PM
RE: parted out 38-116 - by Tom Hamilton - 08-17-2014, 06:55 PM
RE: parted out 38-116 - by SteveJB - 08-17-2014, 09:09 PM
There are currently 7383 online users. [Complete List]
» 1 Member(s) | 7382 Guest(s)
