Need help restoring my 40-180 - SUCCESS
Threads: 145
City: Elko,MN.
I might have a coil for that chassis.
Seemed to me that I have a chassis that I was using for parts.
murf
RE: Need help restoring my 40-180 - by murf - 08-10-2014, 09:41 AM
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 7468 online users. [Complete List] » 2 Member(s) | 7466 Guest(s)
