Dragging out an old nemisis-Philco 66 cathedral-SUCCESS
C24? or C54? R25 shows perfect resistance. Ground of the volume pot?
RE: Dragging out an old nemisis-Philco 66 cathedral - by ccomer1955 - 08-10-2014, 06:47 PM
