116B vs 650B
Here's the completed set. Credit to Barry Jones for the cabinet restoration. Thanks Barry Icon_wink
http://www.youtube.com/watch?v=qSoWQxm9n48
[Image: http://antiqueradios.com/gallery/d/80386-1/116bb.jpg]
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
116B vs 650B - by BDM - 10-20-2008, 09:53 PM
Re: 116B vs 650B - by etech - 10-21-2008, 08:59 PM
Re: 116B vs 650B - by BDM - 10-21-2008, 09:35 PM
Re: 116B vs 650B - by BDM - 10-26-2008, 10:31 PM
Re: 116B vs 650B - by etech - 10-26-2008, 11:46 PM
Re: 116B vs 650B - by BDM - 10-26-2008, 11:51 PM
Re: 116B vs 650B - by Ron Ramirez - 10-27-2008, 10:06 AM
Re: 116B vs 650B - by BDM - 10-27-2008, 10:10 AM
Re: 116B vs 650B - by Doug Houston - 10-27-2008, 04:45 PM
Re: 116B vs 650B - by BDM - 10-27-2008, 08:55 PM
Re: 116B vs 650B - by Texasrocker - 10-30-2008, 03:14 AM
Re: 116B vs 650B - by Doug Houston - 11-01-2008, 10:32 PM
Re: 116B vs 650B - by MinnesotaHam - 12-01-2008, 10:14 PM
Re: 116B vs 650B - by BDM - 12-05-2008, 10:35 PM
Philco 91 Tuning Condenser
