38-38 conversion to AC?
I recently acquired a Philco 38-38 at an auction. It is almost in perfect shape. Is it possible to convert this to run on AC? If so where can this be done?
Thanks in advanced
Greg
38-38 conversion to AC? - by Greg Rodocker - 08-10-2014, 10:32 PM
RE: 38-38 conversion to AC? - by vinzer - 10-05-2017, 04:54 PM
RE: 38-38 conversion to AC? - by Radioroslyn - 10-05-2017, 05:18 PM
RE: 38-38 conversion to AC? - by vinzer - 10-05-2017, 08:28 PM
RE: 38-38 conversion to AC? - by dmaugus - 10-06-2017, 01:38 PM
RE: 38-38 conversion to AC? - by vinzer - 10-07-2017, 08:22 PM
RE: 38-38 conversion to AC? - by vinzer - 10-12-2017, 10:01 PM
RE: 38-38 conversion to AC? - by morzh - 10-12-2017, 10:41 PM
RE: 38-38 conversion to AC? - by vinzer - 10-13-2017, 10:26 PM
RE: 38-38 conversion to AC? - by vinzer - 12-05-2017, 09:28 PM
RE: 38-38 conversion to AC? - by Arran - 12-06-2017, 12:44 AM
The speaker table error?
Philco 70 antenna lead
There are currently 1876 online users. [Complete List]
» 2 Member(s) | 1874 Guest(s)
