Grundig 5005w radio
Is the back missing? It probably has antenna leads marked.
Grundig 5005w radio - by murf - 08-06-2014, 07:49 PM
RE: Grundig 5005w radio - by Paul Philco322 - 08-06-2014, 08:47 PM
RE: Grundig 5005w radio - by murf - 08-06-2014, 09:23 PM
RE: Grundig 5005w radio - by murf - 08-08-2014, 06:44 AM
RE: Grundig 5005w radio - by Ron Ramirez - 08-10-2014, 07:26 AM
RE: Grundig 5005w radio - by Art Hoch - 08-11-2014, 02:37 PM
RE: Grundig 5005w radio - by murf - 08-11-2014, 10:17 PM
RE: Grundig 5005w radio - by Art Hoch - 08-11-2014, 10:49 PM
RE: Grundig 5005w radio - by Ron Ramirez - 08-12-2014, 06:25 AM
RE: Grundig 5005w radio - by murf - 08-12-2014, 07:35 PM
There are currently 3423 online users. [Complete List]
» 1 Member(s) | 3422 Guest(s)
