Need help restoring my 40-180 - SUCCESS
Threads: 8
City: Central PA
How can I test an 84 rectifier tube when I dont have a tube tester? I have been looking online and havent found much to help. Is it just easier to buy another one on ebay for $10?
RE: Need help restoring my 40-180 - by EricS - 08-11-2014, 02:54 PM
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 4066 online users. [Complete List] » 1 Member(s) | 4065 Guest(s)
