Need help restoring my 40-180 - SUCCESS
Threads: 562
And it is 50/50 chance the fuse will still blow.
Eric
you gotta learn how to measure things or you will get quickly frustrated and give up.
The easiest way to check the tube, very basic, is buzz between the
1) Between pins 4 and 2, and then 4 and 3. There should be a clean open, NO conductivity whatsoever. Discard if there is any.
2) Between 1 and 4, and then 5 and 4. Same as above.
3) Between pins 1 and 5. There should be some measurable resistance in Ohms. If open, discard.
In case 1 or 2 are bd, there is a good chance this is your problem with the fuse.
http://www.radiomuseum.org/tubes/tube_84.html
RE: Need help restoring my 40-180 - by morzh - 08-11-2014, 03:06 PM
Users browsing this thread: 16 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 9928 online users. [Complete List] » 3 Member(s) | 9925 Guest(s)
