Need help restoring my 40-180 - SUCCESS
Threads: 562
Well, there you go. Yes, a dead tube is the first usual suspect.
The load short is the second (pretty much 'cause they are lined up left to right in the sch).
However this does not relieve you of the duty to check the load for a short, which is measured across the first electrolytic or, which is the same, pin 4 of the 84 socket and the transformer centertap (or you can use the chassis, then it will be 200 or so Ohm instead of short).
RE: Need help restoring my 40-180 - by morzh - 08-11-2014, 04:09 PM
Users browsing this thread: 15 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 10305 online users. [Complete List] » 1 Member(s) | 10304 Guest(s)
