'42 BOL Drive Wheel
I recently disassembled the "bell drive" on this challenging changer, and sent the drive wheel out for a rebuild. The vendor is asking if Philco has the exact diameter of the rubber at the bottom of the wheel, as well as the tire at the top. Both ends of mine are in bad shape and the changer manual does not seem to show the dimensions. Any help is appreciated as I know some of you have rebuilt these changers in the past.
'42 BOL Drive Wheel - by davidff - 08-12-2014, 08:52 AM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1611 online users. [Complete List]
» 1 Member(s) | 1610 Guest(s)
