16b bakelite cap question
I'm working a 16b-code125 chassis. I have a question about caps in bakelite block #97 on schem. It calls for .3 on schem. and it is a twin cap block. #6287 F which the bakelite chart shows it should have 2-.15 caps inside.
The caps were both connected to lug 1 and then one to lug 2 and other to lug 3 with a wire jumping from 2 to 3.
Did Philco use two .15 caps in parrallel to get the .3 value?
Using capacitor calculator it shows .03 as the value.
I'm down to 2 more bakelite blocks to rebuild and want to make sure I'm clear on what values to use. Thanks . [Image: http://i1336.photobucket.com/albums/o654...5f487c.jpg]t Sorry for the poor schem.
16b bakelite cap question - by KCMike - 08-12-2014, 09:38 PM
RE: 16b bakelite cap question - by klondike98 - 08-12-2014, 09:49 PM
RE: 16b bakelite cap question - by KCMike - 08-12-2014, 09:51 PM
RE: 16b bakelite cap question - by morzh - 08-12-2014, 09:54 PM
RE: 16b bakelite cap question - by KCMike - 08-12-2014, 10:54 PM
RE: 16b bakelite cap question - by morzh - 08-12-2014, 11:02 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
