Rosin solution recipe
Art
Any pure alcohol, that is either grain or isopropyl, and rosin in quantity enough to make the solution yellow.
I used it as a liquid flux for PCBs while a child.
Rosin solution recipe - by Art Hoch - 08-12-2014, 09:56 PM
RE: Rosin solution recipe - by morzh - 08-12-2014, 10:07 PM
RE: Rosin solution recipe - by Warren - 08-12-2014, 11:49 PM
RE: Rosin solution recipe - by JimZ - 08-13-2014, 09:29 AM
RE: Rosin solution recipe - by GarySP - 08-13-2014, 10:16 AM
RE: Rosin solution recipe - by David - 08-13-2014, 10:23 AM
RE: Rosin solution recipe - by Paul Philco322 - 08-13-2014, 05:25 PM
RE: Rosin solution recipe - by morzh - 08-13-2014, 05:48 PM
RE: Rosin solution recipe - by codefox1 - 08-15-2014, 01:40 AM
RE: Rosin solution recipe - by Art Hoch - 08-15-2014, 02:31 PM
RE: Rosin solution recipe - by Paul Philco322 - 08-15-2014, 05:42 PM
RE: Rosin solution recipe - by Pffester - 03-07-2015, 11:36 AM
RE: Rosin solution recipe - by morzh - 03-07-2015, 12:15 PM
RE: Rosin solution recipe - by Pffester - 03-07-2015, 01:18 PM
RE: Rosin solution recipe - by David - 03-07-2015, 01:52 PM
RE: Rosin solution recipe - by Pffester - 03-07-2015, 02:06 PM
