Philco 53-706 restoration Chronicles
I have finally had time to work on my Philco 53-706 lamp radio.
Here she is:
Philco 53-706 restoration Chronicles - by OldRestorer - 08-13-2014, 01:41 PM
RE: Philco 53-706 restoration Chronicles - by sam - 08-16-2014, 01:59 PM
RE: Philco 53-706 restoration Chronicles - by sam - 09-07-2014, 04:45 PM
There are currently 10471 online users. [Complete List]
» 2 Member(s) | 10469 Guest(s)
