Philco 53-706 restoration Chronicles
Kirk, That is good. You can tone it a little red(er).
You should post the artwork for others that have similar radios. If you do, Post the DPI so that it can be sized properly without having to figure it out. I don't have one but I'm sure that someone does.
RE: Philco 53-706 restoration Chronicles - by Phlogiston - 08-13-2014, 02:56 PM
RE: Philco 53-706 restoration Chronicles - by sam - 08-16-2014, 01:59 PM
RE: Philco 53-706 restoration Chronicles - by sam - 09-07-2014, 04:45 PM
There are currently 11169 online users. [Complete List]
» 3 Member(s) | 11166 Guest(s)
