Starting on 66.
WD40 is pretty lame for breaking loose corroded parts. PB Blaster is much better. You can find it in big pray cans at any auto store. For delicate jobs spray some in a little shot glass and use an eye dropper or brush. One can also spray it on rusted parts and use steel wool to clean off the rust as it eats it away.
Starting on 66. - by morzh - 07-23-2014, 10:17 PM
RE: Starting on 66. - by Arran - 07-24-2014, 02:58 AM
RE: Starting on 66. - by morzh - 07-24-2014, 09:59 AM
RE: Starting on 66. - by morzh - 07-24-2014, 04:01 PM
RE: Starting on 66. - by Arran - 07-24-2014, 06:46 PM
RE: Starting on 66. - by morzh - 07-24-2014, 09:02 PM
RE: Starting on 66. - by morzh - 08-04-2014, 08:32 PM
RE: Starting on 66. - by morzh - 08-04-2014, 10:42 PM
RE: Starting on 66. - by morzh - 08-05-2014, 09:30 PM
RE: Starting on 66. - by ccomer1955 - 08-07-2014, 04:42 PM
RE: Starting on 66. - by morzh - 08-07-2014, 04:46 PM
RE: Starting on 66. - by ccomer1955 - 08-09-2014, 09:56 AM
RE: Starting on 66. - by morzh - 08-09-2014, 11:24 AM
RE: Starting on 66. - by ccomer1955 - 08-09-2014, 01:58 PM
RE: Starting on 66. - by morzh - 08-09-2014, 04:37 PM
RE: Starting on 66. - by morzh - 08-12-2014, 09:35 PM
RE: Starting on 66. - by Ron Ramirez - 08-12-2014, 10:41 PM
RE: Starting on 66. - by morzh - 08-12-2014, 11:04 PM
RE: Starting on 66. - by Eric Adams - 08-12-2014, 11:39 PM
RE: Starting on 66. - by morzh - 08-13-2014, 12:37 PM
RE: Starting on 66. - by Eric Adams - 08-13-2014, 01:15 PM
RE: Starting on 66. - by morzh - 08-13-2014, 01:30 PM
RE: Starting on 66. - by Eric Adams - 08-13-2014, 01:51 PM
RE: Starting on 66. - by sam - 08-13-2014, 02:08 PM
RE: Starting on 66. - by Eric Adams - 08-13-2014, 02:28 PM
RE: Starting on 66. - by Chuck Schwark - 08-13-2014, 04:28 PM
RE: Starting on 66. - by mikethedruid - 08-13-2014, 06:02 PM
RE: Starting on 66. - by Eric Adams - 08-13-2014, 06:07 PM
RE: Starting on 66. - by morzh - 08-13-2014, 07:38 PM
RE: Starting on 66. - by morzh - 08-13-2014, 08:08 PM
RE: Starting on 66. - by Mondial - 08-13-2014, 08:18 PM
RE: Starting on 66. - by morzh - 08-13-2014, 09:03 PM
RE: Starting on 66. - by morzh - 08-13-2014, 10:27 PM
RE: Starting on 66. - by Eric Adams - 08-14-2014, 01:09 PM
RE: Starting on 66. - by morzh - 08-14-2014, 01:29 PM
RE: Starting on 66. - by Eric Adams - 08-14-2014, 01:44 PM
RE: Starting on 66. - by morzh - 08-14-2014, 02:14 PM
RE: Starting on 66. - by Eric Adams - 08-14-2014, 02:33 PM
RE: Starting on 66. - by morzh - 08-14-2014, 02:42 PM
RE: Starting on 66. - by Eric Adams - 08-14-2014, 03:04 PM
RE: Starting on 66. - by Warren - 08-14-2014, 04:52 PM
RE: Starting on 66. - by morzh - 08-14-2014, 08:46 PM
RE: Starting on 66. - by Eliot Ness - 08-15-2014, 07:48 AM
RE: Starting on 66. - by Eric Adams - 08-15-2014, 10:02 AM
RE: Starting on 66. - by morzh - 08-28-2014, 09:53 PM
RE: Starting on 66. - by Eric Adams - 08-28-2014, 10:07 PM
RE: Starting on 66. - by morzh - 08-28-2014, 10:31 PM
RE: Starting on 66. - by Arran - 08-29-2014, 01:04 AM
RE: Starting on 66. - by Eric Adams - 08-29-2014, 10:18 AM
RE: Starting on 66. - by morzh - 08-29-2014, 11:25 AM
RE: Starting on 66. - by OldRestorer - 08-29-2014, 11:38 AM
RE: Starting on 66. - by morzh - 08-29-2014, 04:51 PM
RE: Starting on 66. - by morzh - 08-29-2014, 05:30 PM
RE: Starting on 66. - by morzh - 08-29-2014, 05:42 PM
RE: Starting on 66. - by morzh - 08-29-2014, 06:14 PM
RE: Starting on 66. - by morzh - 08-29-2014, 10:10 PM
RE: Starting on 66. - by morzh - 08-30-2014, 08:23 PM
RE: Starting on 66. - by morzh - 08-30-2014, 09:41 PM
RE: Starting on 66. - by morzh - 08-30-2014, 09:43 PM
RE: Starting on 66. - by Warren - 08-31-2014, 12:07 AM
RE: Starting on 66. - by OldRestorer - 08-31-2014, 08:47 AM
RE: Starting on 66. - by morzh - 08-31-2014, 10:30 AM
RE: Starting on 66. - by Radioroslyn - 08-31-2014, 10:48 AM
RE: Starting on 66. - by morzh - 08-31-2014, 11:14 AM
RE: Starting on 66. - by OldRestorer - 08-31-2014, 11:16 AM
RE: Starting on 66. - by morzh - 08-31-2014, 11:25 AM
RE: Starting on 66. - by OldRestorer - 08-31-2014, 11:37 AM
RE: Starting on 66. - by morzh - 08-31-2014, 12:11 PM
There are currently 2185 online users. [Complete List]
» 1 Member(s) | 2184 Guest(s)
