Display of Philco Radios
I was browsing around the Library of Congress web site and came across this photo,
[Image: https://www.dropbox.com/s/bcmz7j12mdazxb....jpg?raw=1]
You can download a high res image if you like. Not much other info on the photo, just kind of neat.
Display of Philco Radios - by klondike98 - 08-13-2014, 09:25 PM
RE: Display of Philco Radios - by SteveJB - 08-14-2014, 12:49 AM
RE: Display of Philco Radios - by morzh - 08-14-2014, 08:50 AM
RE: Display of Philco Radios - by klondike98 - 08-14-2014, 03:34 PM
RE: Display of Philco Radios - by ccomer1955 - 08-14-2014, 10:20 PM
RE: Display of Philco Radios - by PhilcoJohn - 08-20-2014, 08:13 AM
There are currently 10354 online users. [Complete List]
» 1 Member(s) | 10353 Guest(s)
