Threads: 145
City: Elko,MN.
Found both coils were bad.
Replaced with a couple donors from John's chassis and we are working great now.
Thanks everyone.
murf
RE: 41-300x - by murf - 08-13-2014, 10:24 PM
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 8599 online users. [Complete List] » 3 Member(s) | 8596 Guest(s)
