Dragging out an old nemisis-Philco 66 cathedral-SUCCESS
You need to disconnect the lamp and plug it directly to measure voltages.
Do you understand why?
RE: Dragging out an old nemisis-Philco 66 cathedral - by morzh - 08-14-2014, 10:38 PM
There are currently 9761 online users. [Complete List]
» 2 Member(s) | 9759 Guest(s)
