Philco 42-360 Possible Ipod retrofit?
I have a 42-360 That I have restored for a friend, the radio has been in her family for many years and she asked if it was possible to retro fit it so she can plug her Ipod/Iphone in to play music as there is not much on AM. The radio plays beautifully now after recapping and replacing one of the xxl tubes. There is no phono or tv output jack I can tie into so where do I go from here? Can it be done with out tearing up the radio or damaging her phone?
Forgot to add the schematic
http://www.nostalgiaair.org/PagesByModel...013529.pdf
Eric
Philco 42-360 Possible Ipod retrofit? - by Eric - 08-15-2014, 03:39 PM
There are currently 6288 online users. [Complete List]
» 2 Member(s) | 6286 Guest(s)
