Philco Lowboy severed leg repair options?
A good picture of the leg and stub would be important to determine the best approach. If the break is clean (no wood missing) and is following the grain giving a long stretch of contact, glue and clamping might be a better idea. A break nearly horizontal with limited surface a dowel may be the best. The new glues with enough surface to glue to and well clamped for drying can be stronger than the original wood.
JMHO, Jerry
RE: Philco Lowboy severed leg repair options? - by jerryhawthorne - 08-15-2014, 07:05 PM
There are currently 10178 online users. [Complete List]
» 1 Member(s) | 10177 Guest(s)
