Philco 53-706 restoration Chronicles
I've never seen one of those. Love it. Just when we all think you couldn't get better you pull something like this off. Amazing.
RE: Philco 53-706 restoration Chronicles - by sam - 08-16-2014, 01:59 PM
RE: Philco 53-706 restoration Chronicles - by TheBakery - 08-16-2014, 09:47 PM
RE: Philco 53-706 restoration Chronicles - by sam - 09-07-2014, 04:45 PM
There are currently 10197 online users. [Complete List]
» 2 Member(s) | 10195 Guest(s)
