Philco 38-10 redo
It is not the meter, it is a lamp.
As for the meter , it is a simple version of Darsonval/weston galvanometer (as in regular arrow analog meter) attached to a vane that shades the lamp behind it shining through a small opening. Depending on the current (in AVC circuit) the vane rotates making the shade narrow or wide.
Philco 38-10 redo - by Bob Andersen - 08-15-2014, 02:31 PM
RE: Philco 38-10 redo - by codefox1 - 08-15-2014, 02:50 PM
RE: Philco 38-10 redo - by gregb - 08-15-2014, 04:05 PM
RE: Philco 38-10 redo - by Bob Andersen - 08-15-2014, 04:29 PM
RE: Philco 38-10 redo - by Bob Andersen - 08-17-2014, 12:05 AM
RE: Philco 38-10 redo - by morzh - 08-17-2014, 07:03 AM
RE: Philco 38-10 redo - by Bob Andersen - 08-17-2014, 02:15 PM
RE: Philco 38-10 redo - by ccomer1955 - 08-17-2014, 09:11 PM
RE: Philco 38-10 redo - by morzh - 08-17-2014, 10:34 PM
RE: Philco 38-10 redo - by ccomer1955 - 08-18-2014, 12:09 AM
RE: Philco 38-10 redo - by Arran - 08-18-2014, 02:12 AM
RE: Philco 38-10 redo - by mikethedruid - 08-21-2014, 02:54 PM
RE: Philco 38-10 redo - by morzh - 08-21-2014, 03:02 PM
RE: Philco 38-10 redo - by Bob Andersen - 08-30-2014, 03:36 PM
RE: Philco 38-10 redo - by mikethedruid - 08-30-2014, 07:39 PM
RE: Philco 38-10 redo - by morzh - 08-30-2014, 08:18 PM
RE: Philco 38-10 redo - by vinzer - 09-04-2014, 10:20 PM
RE: Philco 38-10 redo - by Nick3092 - 09-05-2014, 10:16 AM
There are currently 8857 online users. [Complete List]
» 3 Member(s) | 8854 Guest(s)
