Dragging out an old nemisis-Philco 66 cathedral-SUCCESS
#32
Do you have the service information for the 66?
IF frequency is 460 kc.
http://www.nostalgiaair.org/PagesByModel...013827.pdf
RE: Dragging out an old nemisis-Philco 66 cathedral - by Ron Ramirez - 08-18-2014, 02:53 PM
There are currently 9942 online users. [Complete List]
» 2 Member(s) | 9940 Guest(s)
