Where to find springs for 1937 knobs?
This tip comes from Mark Oppat (oldradioparts.net):
"Many knobs are found without knob springs. So I came up with a solution.
My secret: Old measuring tape metal. Its easy to cut with scissors and you can add as many layers as works best. The slight arch in the metal works like the old springs."
RE: Where to find springs for 1937 knobs? - by Eliot Ness - 08-18-2014, 05:19 PM
There are currently 7534 online users. [Complete List]
» 3 Member(s) | 7531 Guest(s)
