  • 1 Vote(s) - 5 Average
Second 70 Cabinet Finished
I'm going to go ahead and add the dark accent to the flutes. It is much easier to do it now rather than wait until the cabinet is finished.
[Image: https://farm5.staticflickr.com/4431/3720...e2cf_z.jpg]105_0879 by Steve Davis, on Flickr
[Image: https://farm5.staticflickr.com/4433/3697...e0ab_z.jpg]105_0880 by Steve Davis, on Flickr
I masked off the edges, sprayed two coats of clear to seal the wood, then sprayed the dark toner.
[Image: https://farm5.staticflickr.com/4380/3697...0bf9_z.jpg]105_0884 by Steve Davis, on Flickr
The toner has been sanded off the face of the columns.
[Image: https://farm5.staticflickr.com/4357/3741...d59a_z.jpg]105_0886 by Steve Davis, on Flickr
I have drilled the columns and arch for dowels.
[Image: https://farm5.staticflickr.com/4395/3741...f508_z.jpg]105_0889 by Steve Davis, on Flickr
The columns have been glued to the arch.
[Image: https://farm5.staticflickr.com/4427/3656...e33c_z.jpg]105_0891 by Steve Davis, on Flickr
[Image: https://farm5.staticflickr.com/4346/3656...87c3_z.jpg]105_0892 by Steve Davis, on Flickr
This is the piece that goes across the bottom. I have cut a cope on the ends to match the edge profile of the columns.
M R Radios   C M Tubes
Second 70 Cabinet Finished - by Steve Davis - 08-13-2014, 10:06 PM
RE: Second 70 Cabinet - by morzh - 08-13-2014, 10:30 PM
RE: Second 70 Cabinet - by klondike98 - 08-14-2014, 10:03 AM
RE: Second 70 Cabinet - by morzh - 08-14-2014, 11:20 AM
RE: Second 70 Cabinet - by jerryhawthorne - 08-14-2014, 03:20 PM
RE: Second 70 Cabinet - by Steve Davis - 08-15-2014, 07:12 PM
RE: Second 70 Cabinet - by Arran - 08-15-2014, 11:45 PM
RE: Second 70 Cabinet - by tab10672 - 08-16-2014, 01:23 PM
RE: Second 70 Cabinet - by Steve Davis - 08-16-2014, 08:38 PM
RE: Second 70 Cabinet - by jerryhawthorne - 08-16-2014, 08:54 PM
RE: Second 70 Cabinet - by Steve Davis - 08-16-2014, 09:12 PM
RE: Second 70 Cabinet - by tab10672 - 08-16-2014, 09:22 PM
RE: Second 70 Cabinet - by tab10672 - 08-16-2014, 09:25 PM
RE: Second 70 Cabinet - by jerryhawthorne - 08-16-2014, 11:15 PM
RE: Second 70 Cabinet - by tab10672 - 08-16-2014, 11:52 PM
RE: Second 70 Cabinet - by Steve Davis - 08-17-2014, 08:49 AM
RE: Second 70 Cabinet - by OldRestorer - 08-17-2014, 11:11 AM
RE: Second 70 Cabinet - by Steve Davis - 08-17-2014, 11:54 AM
RE: Second 70 Cabinet - by Steve Davis - 08-17-2014, 03:33 PM
RE: Second 70 Cabinet - by Steve Davis - 08-17-2014, 03:50 PM
RE: Second 70 Cabinet - by Steve Davis - 08-17-2014, 04:21 PM
RE: Second 70 Cabinet - by tab10672 - 08-17-2014, 04:36 PM
RE: Second 70 Cabinet - by jerryhawthorne - 08-17-2014, 04:36 PM
RE: Second 70 Cabinet - by Steve Davis - 08-17-2014, 04:46 PM
RE: Second 70 Cabinet - by tab10672 - 08-17-2014, 05:05 PM
RE: Second 70 Cabinet - by Steve Davis - 08-18-2014, 07:56 PM
RE: Second 70 Cabinet - by OldRestorer - 08-19-2014, 01:45 PM
RE: Second 70 Cabinet - by Steve Davis - 08-19-2014, 04:55 PM
RE: Second 70 Cabinet - by morzh - 08-19-2014, 04:55 PM
RE: Second 70 Cabinet - by Steve Davis - 08-23-2014, 08:49 PM
RE: Second 70 Cabinet - by OldRestorer - 08-24-2014, 12:16 PM
RE: Second 70 Cabinet - by Steve Davis - 08-24-2014, 07:33 PM
RE: Second 70 Cabinet - by Ron Ramirez - 08-24-2014, 08:35 PM
RE: Second 70 Cabinet - by Steve Davis - 08-25-2014, 09:31 AM
RE: Second 70 Cabinet - by Chuck Schwark - 08-25-2014, 10:22 AM
RE: Second 70 Cabinet - by Steve Davis - 08-25-2014, 10:03 PM
RE: Second 70 Cabinet - by Chuck Schwark - 08-26-2014, 09:47 AM
RE: Second 70 Cabinet - by Steve Davis - 08-26-2014, 09:51 AM
RE: Second 70 Cabinet - by Pillo69 - 08-26-2014, 09:58 AM
RE: Second 70 Cabinet - by Steve Davis - 08-26-2014, 10:32 AM
RE: Second 70 Cabinet - by Steve Davis - 08-26-2014, 08:39 PM
RE: Second 70 Cabinet - by Steve Davis - 08-27-2014, 08:12 PM
RE: Second 70 Cabinet - by Steve Davis - 08-27-2014, 09:47 PM
RE: Second 70 Cabinet - by Steve Davis - 09-04-2014, 11:34 AM
RE: Second 70 Cabinet - by OldRestorer - 09-04-2014, 01:09 PM
RE: Second 70 Cabinet - by Steve Davis - 09-06-2014, 09:31 PM
RE: Second 70 Cabinet - by PhilcoJohn - 09-07-2014, 05:24 PM
RE: Second 70 Cabinet - by Steve Davis - 09-07-2014, 07:43 PM
RE: Second 70 Cabinet - by morzh - 09-07-2014, 08:16 PM
RE: Second 70 Cabinet - by Warren - 09-07-2014, 11:06 PM
RE: Second 70 Cabinet - by Arran - 09-08-2014, 12:44 AM
RE: Second 70 Cabinet - by OldRestorer - 09-08-2014, 07:50 AM
RE: Second 70 Cabinet Finished - by morzh - 09-08-2014, 08:39 AM
RE: Second 70 Cabinet Finished - by Eric T - 09-08-2014, 08:53 AM
RE: Second 70 Cabinet Finished - by Eliot Ness - 09-08-2014, 09:05 AM
RE: Second 70 Cabinet Finished - by morzh - 09-08-2014, 09:48 AM
RE: Second 70 Cabinet Finished - by OldRestorer - 09-08-2014, 10:04 AM
RE: Second 70 Cabinet Finished - by Chuck Schwark - 09-08-2014, 10:31 AM
RE: Second 70 Cabinet Finished - by Steve Davis - 09-08-2014, 12:41 PM
RE: Second 70 Cabinet Finished - by OldRestorer - 09-08-2014, 03:52 PM
RE: Second 70 Cabinet Finished - by Steve Davis - 09-08-2014, 04:20 PM
RE: Second 70 Cabinet Finished - by OldRestorer - 09-08-2014, 06:54 PM
RE: Second 70 Cabinet Finished - by morzh - 09-08-2014, 07:13 PM
Users browsing this thread: 19 Guest(s)
There are currently 10326 online users. [Complete List]
» 3 Member(s) | 10323 Guest(s)
