Having a look at the Philco 76
Beautiful Radio! You really like those pre-superhet sets don't you?
Good luck fixing the distortion issue.
Having a look at the Philco 76 - by Radioroslyn - 08-18-2014, 04:09 PM
RE: Having a look at the Philco 76 - by PAradiogeek - 08-19-2014, 10:17 PM
RE: Having a look at the Philco 76 - by morzh - 08-19-2014, 10:37 PM
RE: Having a look at the Philco 76 - by Mondial - 08-20-2014, 07:53 AM
