Where to find springs for 1937 knobs?
Steel tape measures also have a flat clock type spring on the inside that retracts the measuring tape, I've also heard of those being used as a substitute for knobs springs. The pallet straps were a little less useful I found, they were too thick and the steel was too mild though they could work in some cases.
RE: Where to find springs for 1937 knobs? - by Arran - 08-19-2014, 11:15 PM
There are currently 9077 online users. [Complete List]
» 3 Member(s) | 9074 Guest(s)
