Help I need a Rocket Scientist!!!!
Meantime consideing you are dopping a lot, roughly your resistor should be just that, R=112/0.3 Ohms.
Then do C = 1/(6.28*60*R) in Farads (7 uF roughly).
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 02:31 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 02:35 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 02:53 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 03:10 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 04:31 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 05:38 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 07:48 PM
RE: Help I need a Rocket Scientist!!!! - by exray - 08-20-2014, 07:56 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 10:38 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 10:51 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-21-2014, 08:30 PM
RE: Help I need a Rocket Scientist!!!! - by Arran - 08-23-2014, 02:57 AM
There are currently 6124 online users. [Complete List]
» 2 Member(s) | 6122 Guest(s)
