Help I need a Rocket Scientist!!!!
That little Kadette doesn't have very much spare room inside for a dropping capacitor so you might want to consider running it off a variac or set-up a transformer for it. If you do that I'd put something other than a standard AC plug on the cord so someone doesn't plug it into an outlet by mistake.
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 02:31 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 02:35 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 02:53 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 03:10 PM
RE: Help I need a Rocket Scientist!!!! - by Eliot Ness - 08-20-2014, 03:56 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 04:31 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 05:38 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 07:48 PM
RE: Help I need a Rocket Scientist!!!! - by exray - 08-20-2014, 07:56 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 10:38 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 10:51 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-21-2014, 08:30 PM
RE: Help I need a Rocket Scientist!!!! - by Arran - 08-23-2014, 02:57 AM
There are currently 6154 online users. [Complete List]
» 3 Member(s) | 6151 Guest(s)
