Help I need a Rocket Scientist!!!!
Here's a source for suitable caps. 7.5 uf shown, go to links to see other options. Small and relatively inexpensive.
http://www.digikey.com/product-search/en...itor+7.5uf
These are true AC rated caps....not just DC rated in some derated configuration. Dielectric differences, etc, etc
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 02:31 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 02:35 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 02:53 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 03:10 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 04:31 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 05:38 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 07:48 PM
RE: Help I need a Rocket Scientist!!!! - by exray - 08-20-2014, 07:56 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 10:38 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 10:51 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-21-2014, 08:30 PM
RE: Help I need a Rocket Scientist!!!! - by Arran - 08-23-2014, 02:57 AM
There are currently 5903 online users. [Complete List]
» 1 Member(s) | 5902 Guest(s)
