Help I need a Rocket Scientist!!!!
Since you are dropping almost 85% of the voltage you can roughly say that decreasing Rc by x% will raise the load voltage by the same x%.
So if you wanted your fil. voltage to be 18 V it now will be roughly 20V.
But since you drop most volts across the cap, you can add a little resistor and correct it.
As for the math, it is really arithmetics here, the most complex operation being the square root. 6th grade if even that. I am sure this can be understod by anyone once the fear of using calculator is overcome.
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 02:31 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 02:35 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 02:53 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 03:10 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 04:31 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 05:38 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 07:48 PM
RE: Help I need a Rocket Scientist!!!! - by exray - 08-20-2014, 07:56 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 10:38 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-20-2014, 10:51 PM
RE: Help I need a Rocket Scientist!!!! - by morzh - 08-21-2014, 08:30 PM
RE: Help I need a Rocket Scientist!!!! - by Arran - 08-23-2014, 02:57 AM
There are currently 5877 online users. [Complete List]
» 1 Member(s) | 5876 Guest(s)
