Philco 16B tombstone
Let us know if you have replaced all the electrolytic and paper capacitors and cleaned all controls, switches and tube sockets and tube pins. Could also be a failing carbon resistor, I'd replace all in the audio amplifier section to start.
Then if you have same noise with volume control all the way down, problem is almost certainly after the volume control in the audio amplifier/speaker or voltage divider areas.
Philco 16B tombstone - by fields 100 - 08-20-2014, 11:28 PM
RE: Philco 16B tombstone - by codefox1 - 08-21-2014, 05:39 AM
RE: Philco 16B tombstone - by morzh - 08-21-2014, 07:07 AM
RE: Philco 16B tombstone - by Steve Davis - 08-21-2014, 07:30 AM
RE: Philco 16B tombstone - by fields 100 - 08-21-2014, 07:34 AM
RE: Philco 16B tombstone - by fields 100 - 08-25-2014, 09:35 AM
RE: Philco 16B tombstone - by AI2V - 08-25-2014, 08:12 PM
RE: Philco 16B tombstone - by fields 100 - 08-25-2014, 09:07 PM
There are currently 9651 online users. [Complete List]
» 3 Member(s) | 9648 Guest(s)
