Need help restoring my 40-180 - SUCCESS
#85
Thanks for the protocol, Morzh. Should the other tubes be installed when I power up? I'm thinking I want to put my light bulb inline with the ac cord to make sure it doesn't glow brightly still.
RE: Need help restoring my 40-180 - by marty - 08-26-2013, 02:12 PM
RE: Need help restoring my 40-180 - by EricS - 08-26-2013, 02:33 PM
RE: Need help restoring my 40-180 - by klondike98 - 08-26-2013, 02:42 PM
RE: Need help restoring my 40-180 - by EricS - 08-26-2013, 02:48 PM
RE: Need help restoring my 40-180 - by marty - 08-26-2013, 03:04 PM
RE: Need help restoring my 40-180 - by EricS - 08-26-2013, 09:46 PM
RE: Need help restoring my 40-180 - by EricS - 08-27-2013, 08:50 AM
RE: Need help restoring my 40-180 - by marty - 08-27-2013, 10:08 AM
RE: Need help restoring my 40-180 - by EricS - 08-27-2013, 10:56 AM
RE: Need help restoring my 40-180 - by Jamie - 08-27-2013, 03:16 PM
RE: Need help restoring my 40-180 - by codefox1 - 08-27-2013, 06:25 PM
RE: Need help restoring my 40-180 - by marty - 08-27-2013, 07:43 PM
RE: Need help restoring my 40-180 - by marty - 08-27-2013, 08:55 PM
RE: Need help restoring my 40-180 - by EricS - 08-27-2013, 10:45 PM
RE: Need help restoring my 40-180 - by EricS - 08-28-2013, 06:53 PM
RE: Need help restoring my 40-180 - by marty - 08-28-2013, 07:00 PM
RE: Need help restoring my 40-180 - by Raleigh - 08-28-2013, 07:37 PM
RE: Need help restoring my 40-180 - by EricS - 08-29-2013, 09:47 PM
RE: Need help restoring my 40-180 - by marty - 08-29-2013, 10:23 PM
RE: Need help restoring my 40-180 - by EricS - 09-08-2013, 08:33 PM
RE: Need help restoring my 40-180 - by TA Forbes - 09-08-2013, 08:52 PM
RE: Need help restoring my 40-180 - by EricS - 09-08-2013, 08:58 PM
RE: Need help restoring my 40-180 - by EricS - 09-08-2013, 09:44 PM
RE: Need help restoring my 40-180 - by EricS - 09-09-2013, 08:29 AM
RE: Need help restoring my 40-180 - by morzh - 09-11-2013, 10:22 PM
RE: Need help restoring my 40-180 - by BrendaAnnD - 09-12-2013, 12:35 AM
RE: Need help restoring my 40-180 - by BrendaAnnD - 09-13-2013, 04:51 AM
RE: Need help restoring my 40-180 - by BrendaAnnD - 09-13-2013, 12:19 PM
RE: Need help restoring my 40-180 - by EricS - 09-20-2013, 11:41 PM
RE: Need help restoring my 40-180 - by EricS - 10-11-2013, 07:32 PM
RE: Need help restoring my 40-180 - by Jamie - 10-11-2013, 08:00 PM
RE: Need help restoring my 40-180 - by EricS - 10-13-2013, 07:25 PM
RE: Need help restoring my 40-180 - by EricS - 10-23-2013, 09:28 PM
RE: Need help restoring my 40-180 - by DeckApe - 10-28-2013, 06:11 PM
RE: Need help restoring my 40-180 - by EricS - 10-28-2013, 10:17 PM
RE: Need help restoring my 40-180 - by DeckApe - 11-21-2013, 01:19 PM
RE: Need help restoring my 40-180 - by EricS - 08-10-2014, 09:04 AM
RE: Need help restoring my 40-180 - by murf - 08-10-2014, 09:41 AM
RE: Need help restoring my 40-180 - by murf - 08-10-2014, 09:57 AM
RE: Need help restoring my 40-180 - by morzh - 08-10-2014, 11:51 AM
RE: Need help restoring my 40-180 - by EricS - 08-10-2014, 04:09 PM
RE: Need help restoring my 40-180 - by morzh - 08-10-2014, 04:13 PM
RE: Need help restoring my 40-180 - by EricS - 08-10-2014, 10:10 PM
RE: Need help restoring my 40-180 - by morzh - 08-10-2014, 10:18 PM
RE: Need help restoring my 40-180 - by EricS - 08-10-2014, 11:14 PM
RE: Need help restoring my 40-180 - by EricS - 08-11-2014, 08:32 AM
RE: Need help restoring my 40-180 - by morzh - 08-11-2014, 09:37 AM
RE: Need help restoring my 40-180 - by EricS - 08-11-2014, 02:54 PM
RE: Need help restoring my 40-180 - by morzh - 08-11-2014, 03:06 PM
RE: Need help restoring my 40-180 - by EricS - 08-11-2014, 03:58 PM
RE: Need help restoring my 40-180 - by morzh - 08-11-2014, 04:09 PM
RE: Need help restoring my 40-180 - by morzh - 08-11-2014, 04:13 PM
RE: Need help restoring my 40-180 - by EricS - 08-21-2014, 09:17 PM
RE: Need help restoring my 40-180 - by morzh - 08-21-2014, 09:40 PM
RE: Need help restoring my 40-180 - by EricS - 08-21-2014, 10:49 PM
RE: Need help restoring my 40-180 - by EricS - 08-22-2014, 08:33 AM
RE: Need help restoring my 40-180 - by EricS - 08-22-2014, 08:50 AM
RE: Need help restoring my 40-180 - by morzh - 08-22-2014, 10:51 AM
RE: Need help restoring my 40-180 - by EricS - 08-22-2014, 06:48 PM
RE: Need help restoring my 40-180 - by morzh - 08-22-2014, 07:11 PM
RE: Need help restoring my 40-180 - by EricS - 08-22-2014, 10:37 PM
RE: Need help restoring my 40-180 - by morzh - 08-22-2014, 10:58 PM
RE: Need help restoring my 40-180 - by EricS - 08-25-2014, 09:01 PM
RE: Need help restoring my 40-180 - by murf - 08-25-2014, 09:48 PM
RE: Need help restoring my 40-180 - by EricS - 08-26-2014, 12:51 PM
RE: Need help restoring my 40-180 - by EricS - 08-28-2014, 09:59 PM
There are currently 4562 online users. [Complete List]
» 1 Member(s) | 4561 Guest(s)
