The cabinet refinishing.
Kirk,
You are too modest.Your cabinets are excellent to say the least.You could be new to the radio restoration, but definitely not to the woodwork finish.
I use for my work regular auto touch up spray gun (sometimes they call it "mini").
I tried both ways and found out that the lacquer you are using is easier to compound if done by hand. With an orbital buffer it does not matter.You see, I have never seen or touched the perfect original to compare and my concern is always overdoing it.Some high end radios did have the piano look like finish, but with cathedrals I simply do not know.
The cabinet refinishing. - by fields 100 - 08-21-2014, 11:57 PM
RE: The cabinet refinishing. - by Arran - 08-22-2014, 02:47 AM
RE: The cabinet refinishing. - by Warren - 08-22-2014, 03:04 AM
RE: The cabinet refinishing. - by fields 100 - 08-22-2014, 07:46 AM
RE: The cabinet refinishing. - by OldRestorer - 08-22-2014, 07:52 AM
RE: The cabinet refinishing. - by fields 100 - 08-22-2014, 08:21 AM
RE: The cabinet refinishing. - by OldRestorer - 08-22-2014, 08:50 AM
RE: The cabinet refinishing. - by Warren - 08-22-2014, 09:48 PM
RE: The cabinet refinishing. - by fields 100 - 08-23-2014, 08:59 AM
RE: The cabinet refinishing. - by Warren - 08-23-2014, 03:32 PM
RE: The cabinet refinishing. - by fields 100 - 08-23-2014, 08:14 PM
RE: The cabinet refinishing. - by Warren - 08-24-2014, 12:21 AM
RE: The cabinet refinishing. - by fields 100 - 08-24-2014, 07:22 AM
RE: The cabinet refinishing. - by aab1991 - 03-02-2015, 01:00 AM
RE: The cabinet refinishing. - by Warren - 08-24-2014, 03:26 PM
RE: The cabinet refinishing. - by Geoff - 08-24-2014, 11:56 PM
RE: The cabinet refinishing. - by Warren - 08-25-2014, 01:15 AM
RE: The cabinet refinishing. - by Bob Andersen - 08-27-2014, 12:30 AM
RE: The cabinet refinishing. - by PhilcoJohn - 08-27-2014, 07:31 AM
RE: The cabinet refinishing. - by fields 100 - 08-27-2014, 08:29 AM
RE: The cabinet refinishing. - by Warren - 08-27-2014, 04:16 PM
RE: The cabinet refinishing. - by fields 100 - 08-27-2014, 04:46 PM
RE: The cabinet refinishing. - by Warren - 08-27-2014, 07:55 PM
RE: The cabinet refinishing. - by fields 100 - 08-27-2014, 09:31 PM
RE: The cabinet refinishing. - by Warren - 08-27-2014, 10:21 PM
RE: The cabinet refinishing. - by fields 100 - 08-28-2014, 08:04 AM
RE: The cabinet refinishing. - by Phlogiston - 08-28-2014, 10:04 AM
RE: The cabinet refinishing. - by fields 100 - 08-28-2014, 03:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7528 online users. [Complete List]
» 3 Member(s) | 7525 Guest(s)
