Recap Question
Thanks Ron.
If you don't mind, I have a few more questions regarding the caps.
1. Are the caps that are said to be part of another part replaceable( ie the compensating caps or the 1pF that is part of the tuning cap )?
2. What's the difference between a Bakelite block and a Twin Bakelite block?
3. Part 67 says it is an 8uF & 8uF Electrolytic. I take it that this is a multi-section cap. Do I need to replace with the same?
Thanks for all of the help. I'm just getting started in this, and need all the help I can get.
Derek
Recap Question - by Derek D - 12-13-2005, 12:22 PM
[No subject] - by Ron Ramirez - 12-13-2005, 01:22 PM
[No subject] - by Derek D - 12-13-2005, 03:03 PM
[No subject] - by Ron Ramirez - 12-13-2005, 05:56 PM
[No subject] - by Derek D - 12-18-2005, 07:46 PM
[No subject] - by Ron Ramirez - 12-18-2005, 08:06 PM
There are currently 5654 online users. [Complete List]
» 2 Member(s) | 5652 Guest(s)
