Philco Model 70 -- Help
diamondust Wrote:It now has very good sensitivity and selectivity but the volume could be much better. Seems that when I touch the volume control , the R.F.grid or the ant. clip, the volume almost doubles.
Do you have an antenna connected to the set? It needs at least 25 feet of wire; longer is better.
diamondust Wrote:When I test voltages the screen grid volts are about one and a half times what they should be -- the control grids are about five times what they should be!! -- Cathode volts are about one and a half times . The even stranger thing is that the " 24 " second detector plate has over the double ( 230 v. ) what it should be!! The other plates are only sl. high.
Did you check all resistor values? What is your line voltage?
Philco Model 70 -- Help - by Guest - 10-02-2008, 05:51 PM
Re: Philco Model 70 -- Help - by Ron Ramirez - 10-02-2008, 06:33 PM
Re: Philco Model 70 -- Help - by Chuck Schwark - 10-03-2008, 09:38 AM
Re: Philco Model 70 -- Help - by Guest - 10-03-2008, 12:23 PM
91H Code 126 Restore
There are currently 2660 online users. [Complete List]
» 1 Member(s) | 2659 Guest(s)
