116 chassis, loss of reception
Check B+ on the plate and screen grid of your RF tube, Type 78. Sounds to me as if it has stopped functioning? Maybe a dirty band switch? Worst case scenario...bad antenna coil.
116 chassis, loss of reception - by BDM - 10-04-2008, 10:53 PM
Re: 116 chassis, loss of reception - by Ron Ramirez - 10-04-2008, 11:26 PM
Re: 116 chassis, loss of reception - by BDM - 10-04-2008, 11:50 PM
Re: 116 chassis, loss of reception - by BDM - 10-05-2008, 01:21 AM
Re: 116 chassis, loss of reception - by BDM - 10-05-2008, 01:45 AM
Re: 116 chassis, loss of reception - by exray - 10-05-2008, 07:28 AM
Re: 116 chassis, loss of reception - by mandh - 10-05-2008, 08:35 AM
Re: 116 chassis, loss of reception - by BDM - 10-05-2008, 12:16 PM
Re: 116 chassis, loss of reception - by BDM - 10-17-2008, 01:25 AM
Re: 116 chassis, loss of reception - by BDM - 10-18-2008, 06:35 PM
Re: 116 chassis, loss of reception - by etech - 10-18-2008, 10:55 PM
