philco 80 jr. help please. 1st time restoring a radio this old
Ron would have a better grasp on interchangeability of volume pots than me. Gary at Playthings will advise you, though. Just be sure your communications follow his rules listed on the "How to order" page when you write to him.
Charlie in San Antonio
RE: philco 80 jr. help please. 1st time restoring a radio this old - by ccomer1955 - 08-24-2014, 08:23 PM
There are currently 9980 online users. [Complete List]
» 1 Member(s) | 9979 Guest(s)
