No built in speaker in my 19LZ Ugh
The speaker Bob (klondike98 ) linked to is for a 14LZX, not a 19LZX. But it could be adapted to use with a 19LZX with a little work. You would have to replace the dual speaker setup with a single 10-1/2 inch speaker with 1140 ohm field and single-ended output transformer, and make a few changes to the control box in back of the speaker cabinet.
$75 is a very good price for that speaker cabinet, which is just as hard to find as a 19LZX/19TX speaker cabinet. It wouldn't be cheap to have it shipped from coast to coast, however.
But then, I would not trust that flat cable after 81 years - this cable's conductors has the infamous rubber insulation. Icon_eek You would have to replace the cable...and you won't find a flat cable with conductors large enough to handle the voltages and currents involved...so you would have to settle for a round cable, which won't look original but will do the job.
Or just add the 8 inch speaker inside the chairside cabinet and have a 19LZ.
Either way, a bit of work will be involved...but worth it, I think. Icon_smile
RE: No built in speaker in my 19LZ Ugh - by sam - 08-24-2014, 05:00 PM
RE: No built in speaker in my 19LZ Ugh - by sam - 08-24-2014, 07:43 PM
RE: No built in speaker in my 19LZ Ugh - by sam - 08-24-2014, 07:56 PM
RE: No built in speaker in my 19LZ Ugh - by Ron Ramirez - 08-24-2014, 08:31 PM
RE: No built in speaker in my 19LZ Ugh - by Skip - 08-25-2014, 06:22 PM
RE: No built in speaker in my 19LZ Ugh - by Skip - 08-25-2014, 06:43 PM
There are currently 6452 online users. [Complete List]
» 1 Member(s) | 6451 Guest(s)
