Philco PT6
I wanted to stop the surge. I Thought using too high of a value causes higher voltages..
thanks mondial.
Philco PT6 - by bfrohwein - 08-24-2014, 04:05 PM
RE: Philco PT6 - by morzh - 08-24-2014, 10:41 PM
RE: Philco PT6 - by Mondial - 08-24-2014, 11:08 PM
RE: Philco PT6 - by bfrohwein - 08-24-2014, 11:28 PM
RE: Philco PT6 - by Mondial - 08-24-2014, 11:42 PM
RE: Philco PT6 - by Arran - 08-25-2014, 12:52 AM
RE: Philco PT6 - by bfrohwein - 08-25-2014, 02:18 AM
RE: Philco PT6 - by bfrohwein - 08-26-2014, 10:28 PM
RE: Philco PT6 - by bfrohwein - 09-01-2014, 12:39 PM
There are currently 9668 online users. [Complete List]
» 3 Member(s) | 9665 Guest(s)
