Philco PT6
It's a 1941 PT2 in a wooden case.
I was going to use a CL90 to begin with. but I was thinking about the heat and probably a little bored and wanted something exotic. my 53-701 has one of those tube savers in there. If I remember correctly it said 680 @ room temperature and 100 when hot. Although on that set they use the heater tap on the 35W4.
Philco PT6 - by bfrohwein - 08-24-2014, 04:05 PM
RE: Philco PT6 - by morzh - 08-24-2014, 10:41 PM
RE: Philco PT6 - by Mondial - 08-24-2014, 11:08 PM
RE: Philco PT6 - by bfrohwein - 08-24-2014, 11:28 PM
RE: Philco PT6 - by Mondial - 08-24-2014, 11:42 PM
RE: Philco PT6 - by Arran - 08-25-2014, 12:52 AM
RE: Philco PT6 - by bfrohwein - 08-25-2014, 02:18 AM
RE: Philco PT6 - by bfrohwein - 08-26-2014, 10:28 PM
RE: Philco PT6 - by bfrohwein - 09-01-2014, 12:39 PM
There are currently 9426 online users. [Complete List]
» 3 Member(s) | 9423 Guest(s)
