116 chassis, loss of reception
Thanks Ron. I'm at a loss right now. The band switch wafer looks good. The 110/pf cap has been replaced, not that would cause this. Without that coupling cap, it has nothing.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
116 chassis, loss of reception - by BDM - 10-04-2008, 10:53 PM
Re: 116 chassis, loss of reception - by BDM - 10-04-2008, 11:50 PM
Re: 116 chassis, loss of reception - by BDM - 10-05-2008, 01:21 AM
Re: 116 chassis, loss of reception - by BDM - 10-05-2008, 01:45 AM
Re: 116 chassis, loss of reception - by exray - 10-05-2008, 07:28 AM
Re: 116 chassis, loss of reception - by mandh - 10-05-2008, 08:35 AM
Re: 116 chassis, loss of reception - by BDM - 10-05-2008, 12:16 PM
Re: 116 chassis, loss of reception - by BDM - 10-17-2008, 01:25 AM
Re: 116 chassis, loss of reception - by BDM - 10-18-2008, 06:35 PM
Re: 116 chassis, loss of reception - by etech - 10-18-2008, 10:55 PM
