Philco 53 table top
I am researching the radios I bought and cant seem to find this Philco 53 anywhere online or in the Philco database. I could just be Icon_crazy
Anyone know?
Philco 53 table top - by OldRestorer - 08-25-2014, 09:17 AM
RE: Philco 53 table top - by Chuck Schwark - 08-25-2014, 09:25 AM
RE: Philco 53 table top - by tab10672 - 08-25-2014, 09:51 AM
RE: Philco 53 table top - by tab10672 - 08-25-2014, 09:55 AM
RE: Philco 53 table top - by morzh - 08-25-2014, 10:07 AM
RE: Philco 53 table top - by OldRestorer - 08-25-2014, 11:05 AM
There are currently 10258 online users. [Complete List]
» 4 Member(s) | 10254 Guest(s)
AvatarAvatarAvatarAvatar
