Philco 53C to strip or not to strip?
I have here a fine looking piece of Philco history but I cannot decide whether to strip it or leave it.
I gave it the Gojo but the top left finish is gone. front and sides are great though.
Do I leave it original and just seal the top or should it be redone?
I like original but the top is killing it. I cant just redo the top because it all curves together.
Here it is:
Philco 53C to strip or not to strip? - by OldRestorer - 08-25-2014, 12:13 PM
RE: Philco 53C to strip or not to strip? - by sam - 08-27-2014, 07:25 PM
There are currently 10546 online users. [Complete List]
» 2 Member(s) | 10544 Guest(s)
