Speaker repair tutorial
OldRestorer Wrote:I figured since I did not see any threads on speaker repair
Syl Vanier posted an excellent tutorial on speaker repair on the Phorum several years ago. Here's the link:
http://www.philcoradio.com/phorum/showth...p?tid=1003
Speaker repair tutorial - by OldRestorer - 04-09-2014, 08:28 AM
RE: Speaker repair tutorial - by morzh - 04-09-2014, 09:21 AM
RE: Speaker repair tutorial - by Phlogiston - 04-09-2014, 09:44 AM
RE: Speaker repair tutorial - by captainslack - 04-09-2014, 01:36 PM
RE: Speaker repair tutorial - by K7Sparky - 04-10-2014, 07:11 AM
RE: Speaker repair tutorial - by TA Forbes - 04-10-2014, 01:03 PM
RE: Speaker repair tutorial - by OldRestorer - 04-10-2014, 06:32 PM
RE: Speaker repair tutorial - by voroush - 04-16-2014, 03:26 PM
RE: Speaker repair tutorial - by mornflt - 08-25-2014, 02:20 PM
RE: Speaker repair tutorial - by Ron Ramirez - 08-25-2014, 06:04 PM
RE: Speaker repair tutorial - by radiohenry - 08-25-2014, 06:49 PM
RE: Speaker repair tutorial - by Ron Ramirez - 08-25-2014, 08:26 PM
There are currently 9935 online users. [Complete List]
» 1 Member(s) | 9934 Guest(s)
