Philco 53C to strip or not to strip?
When I said , several coats, I meant on the area with the finish missing only. The tint would be to match the yellowing that has occurred to the original finish. BTW, yellow is not good, very little brown in gloss or semi gloss lacquer will do it.
RE: Philco 53C to strip or not to strip? - by Phlogiston - 08-25-2014, 06:34 PM
RE: Philco 53C to strip or not to strip? - by sam - 08-27-2014, 07:25 PM
