philco 80 jr. help please. 1st time restoring a radio this old
Well, the AC volage is about 700V, as it is a full wave centerpoint that cuts the output in half
The highest DC you see is 400V with excursion to 500V fr a few seconds.
This does not mean the wire has to withstand 700V.
But typical insulation will be a 600V type
RE: philco 80 jr. help please. 1st time restoring a radio this old - by morzh - 08-26-2014, 06:42 AM
Users browsing this thread: 17 Guest(s)
There are currently 10208 online users. [Complete List]
» 3 Member(s) | 10205 Guest(s)
