Cabinet problems
Did you use grain filler? Sounds like you skipped that step. If you've only put on one coat of lacquer you could still fill the grain. In fact some fellows insist on doing it that way. Then apply your final coat.
Cabinet problems - by Robert - 10-05-2008, 02:21 PM
Re: Cabinet problems - by exray - 10-05-2008, 03:41 PM
Re: Cabinet problems - by Robert - 10-05-2008, 03:48 PM
There are currently 4547 online users. [Complete List]
» 1 Member(s) | 4546 Guest(s)
