  • 1 Vote(s) - 5 Average
mute philco 19 or 89 or all between
Quote:I'd also start looking for another speaker if I was serious about restoring this radio. I didn't notice wire nuts in your picture, but someone has been in there and used some modern wire for their repair. And if they crammed a modern speaker in there I'd be suspect of their other repairs.
I agree. You really need another speaker.
M R Radios   C M Tubes
RE: mute philco 19 or 89 or all between - by Steve Davis - 08-26-2014, 01:37 PM
RE: mute philco 19 or 89 or all between - by confused2 - 08-29-2014, 09:37 AM
RE: mute philco 19 or 89 or all between - by confused2 - 08-29-2014, 09:51 AM
There are currently 9953 online users. [Complete List]
» 3 Member(s) | 9950 Guest(s)
